2001 DiscoII 4wd no shifty
Old Oct 28, 2009 | 01:52 PM
Aaron1976's Avatar
Default 2001 DiscoII 4wd no shifty
Hey everyone,
I am working on my friends 2001 Disco II and he has the same problem (sort of) as I had with my Disco I when I first bought it.
The 4wd range shifter won't shift out of hi. It moves a bit bit it is stuck. The linkage and cable are moving but the lever at the transfer case seems to be stuck.
Anyone know what to do besides force the lever to move with something like a hammer and a long rod?
Thanks,
Aaron
Old Oct 28, 2009 | 01:54 PM
sloppyjoe's Avatar
Originally Posted by aaron1976
hey everyone,
i am working on my friends 2001 disco ii and he has the same problem (sort of) as i had with my disco i when i first bought it.
Thanks,
aaron:d
wd-40
Old Oct 28, 2009 | 03:20 PM
Aaron1976's Avatar
Default tranfer case help SOS
So I took the center console out and I can see down through the plate that is riveted on and I can see the lower linage arm going into the transfer case move just a little bit with the cable and shifter.
Is there a switch that would mechanicely lock the linkage from moving like the gear selector for the transmission?
There must be something internally wrong or frozen up to cause this.
Old Oct 28, 2009 | 08:25 PM
There is a ball joint inside there that is lubed with greased at the factory, it can get full of condensation and rust up.
I think that there is also a solenoid in there too and can go bad.
I know there is one on a DI but not sure about a DII.
Old Oct 29, 2009 | 09:33 AM
Aaron1976's Avatar
I found a diagram that I was going to post for you all that view this thread for future reference but I can't find the diagram now so I will try to explain this.
There is a shift lockout solenoid on the transfer case. It is a safety device to ensure you don't shift it at the wrong time. Most of us know what to do so those of us that do know how to shift into low range and at what time and in what gear (n) can remove the solenoid plunger.
The solenoid is located on the rear portion of the transfer case and on top of the transfer case. It is to the rear of the shift linkage for the high and low range. It is a round housing with one bolt on either side, two bolts total. You will also see two wires going in to it or just off to the side of it. remove the two bolts and pull the solenoid out. Then grind off the plunger or hack saw it off. Install the solenoid and your done with that part.
You have to do this from inside the Rover and having the center console removed along with the plate that the shifters are attached to. The plate is held on by 13 rivets, you have to drill those and replace them when you re-assemble the console.
Also the E brake handle needs to be mostly straight up to get the console out so you most likely will need to unhook the cable from the handle.
Hope this will help anyone who has been stuck in either high or low range and can't shift your Discovery.
As I understand it, Rover started with the lockout solenoid in the states in 93 so all Discos should have them.
Please be sure your shift linkage and or shift handle is not froze up before you go to the solenoid. My D1 was frozen up at the shift handle housing and I was able to free it up with some penetrating oil and a little impact force from a rubber mallet. Be careful not to break anything when you do this.
Old Oct 29, 2009 | 11:45 AM
The solenoid in the t/case is shot and won't release the t/case to shift to low when the tranny is out of gear.
You either remove or replace the solenoid and the problem is fixed.
Here is a picture of the case, remove the 4 bolt from the top cover, slip the solenoid out and either replace it or go without it, and reinstall the cover.
Old May 21, 2013 | 09:08 AM
Dean's Avatar
This thread really help me with this stuck high/low range selector. Thought it could use another picture. Hope this helps.
Spencerfitch
Apr 12, 2010 04:08 PM
Charles68
Jul 26, 2009 08:48 AM
focusontheworld
Dec 1, 2007 11:30 PM
disco2adam
Nov 3, 2007 07:24 PM
