2001 discovery 2
Old Nov 27, 2021 | 09:38 PM
Travis James's Avatar
5th Gear
Default 2001 discovery 2
Hello all,I acquired a 2001 discovery 2 a couple years ago.. I've been very happy with it.. along the way I've had issues mostly small.. however the gauge or cluster doesn't work.. I'm thinking it's a ground but I'm not sure.. the cluster lights up but the needles do nothing.. I found what appears to be a ground wire underneath the steering wheel that is ripped off of it's eyelet... I'm not sure where the wire is located or if it's factory original.. the eyelet is the only thing remaining I can't locate the wire that was attached to it.. any help would be appreciated
Old Nov 28, 2021 | 11:00 AM
greisinb's Avatar
When you say “lights up” do you mean that the warning lights illuminate when you turn the key is in the ON position or do you mean that instrument illumination lights turn on when you turn on the headlights? They use different circuits with the warning lights using the same ground as the gauges.
Old Dec 8, 2021 | 12:29 AM
5th Gear
this is the location of what appears to be a ground of some sort.. is this OEM?
Close up
So I wasn't able to check if the dummie lights lit up on the cluster.. battery was dead.. I try to start and run it enough to keep the battery up.. evidently I waited too long... although I managed to snap a couple pics of some of this wire hackery that happened prior to me acquiring it.
Old Dec 8, 2021 | 01:05 PM
greisinb's Avatar
Wow...that's some questionable wiring. Do you have access to the D2 electrical circuit PDF? I've found it to be invaluable:
https://discoii.files.wordpress.com/...grams_2000.pdf
Old Dec 10, 2021 | 09:11 AM
5th Gear
Thank you, this is helpful..
Travis James
Feb 28, 2022 04:21 PM
blackcatphil
Jul 2, 2014 05:11 PM
wheelgarage
Jul 14, 2011 08:51 AM
ajh
Oct 4, 2007 08:44 AM
coldfrez
Oct 1, 2007 09:49 AM
