2001 Discovery - Rear Suspension
Old May 11, 2011 | 12:26 AM
Kimberl563's Avatar
4th Gear
Default 2001 Discovery - Rear Suspension
So - one of my friends put 18 bags of dirt into the back of her Discovery. The rear end is now sitting low - like low rider low to the point that it is kinda funny like you expect it to start bouncing up and down with hydraulics. Any ideas to fix this? When the mechanic looked at it he was clueless (it was in for a new front drive shaft).
Is there a fuse - a reset - or something?
When it was up on the rack the air bags didn't look like they had a leak. I also don't know of the compressor is working or not either but the start of the issue was all that damn dirt.
Any suggestions would be appreciated.
Old May 11, 2011 | 08:03 AM
vandev's Avatar
Default save yourself..
save yourself money, time and great frustration... get rid of the bags and get springs....About $100.00 used in new condition..take you a couple hours to change out yourself with no special tools and your good to go...had a RR for years and always a issue...
Chris
Old May 11, 2011 | 08:07 PM
buick215's Avatar
Chris
FYI, he is going to need more than just used springs if he decides to go that route. He is going to need spring seats and the hardware associated with it. He might as well just buy the kit that comes with everything needed for the conversion.
Old May 11, 2011 | 08:12 PM
DarylJ's Avatar
And someone who can program the BCU.
Old May 11, 2011 | 08:21 PM
This will solve your problem for once and for all.
Land Rover Discovery II Rear Air Suspension & Coil Spring Kit - Land Rover Parts & Accessories At Atlantic British
Your friend either broke a height sensor or knocked it to far out of range for it to give a correct reading and the compressor is not coming on because the ECU does not know the truck is sitting to low.
Old May 12, 2011 | 02:42 PM
Kimberl563's Avatar
4th Gear
Default Fixed :)
I had the mechanic put it up on the rack overnight. Then when he brought it down I had him reset the on-board computer. Rear Air Suspension re-adjusted and is just dandy now
ajbilliot
Jan 10, 2011 10:41 PM
johnkbl
Jan 19, 2010 05:22 AM
mherson
Aug 25, 2009 09:41 PM
Charles68
Jul 26, 2009 08:48 AM
CANAMDiscovery
Apr 29, 2009 12:16 AM
