2001 Rover startup ROUGH
Old Sep 12, 2014 | 10:37 AM
ggushee's Avatar
Default 2001 Rover startup ROUGH
Yesterday i was driving my rover. As i approached an upward turn, the rover hesitated with loss of power, corrected itself and all was fine. A few minutes later when i started up my rover the engine sounded awful. It then quickly corrected itself. I drove it for some distance. Turned it off and restarted. All was fine. I then drove the vehicle for 30 minutes and all seemed to be fine. Any ideas on what might have happened or what might be a DEVELOPING ISSUE?
Old Sep 12, 2014 | 09:37 PM
Two Rock's Avatar
First step for me would be to see if there were any stored or pending codes in the ECU which could give u a clue as to what the issue might be.
Old Sep 12, 2014 | 09:55 PM
jfall's Avatar
Could be fuel pump failing.
If around 150K or above - replace the fuel pump.
Or you will end up stranded.
dmatranga
Feb 6, 2014 01:48 PM
zenithgarfunkel
Dec 21, 2013 10:26 AM
starcraft1
Mar 18, 2010 06:20 AM
MLX665GP
Jul 14, 2008 09:10 AM
microbc
May 22, 2008 03:15 PM
