2001 Won't Start
Old Oct 8, 2012 | 06:27 PM
hawken89's Avatar
4th Gear
Cool 2001 Won't Start
Hi everyone!
Hope you can help as I am not sure what direction to go in.
My 2001 Discovery won't start consistently. Yesterday it was fine, today it started up 2 times no problem. On the third it was the same as all of the other times it won't start: all the lights are on, the ac is on, i turn the key and nothing. it's like the car is in gear...which it is not.
In the past i have tried to jump it and it didn't do anything to help. But 15 minutes later it cranks right up. again all the interior lights were on, radio, etc
Battery? Seems strange that everything else lights up
Starter? It doesn't click which happened about 3 years ago when i had to relace the starter.
Help wanted and appreciated!
Old Oct 8, 2012 | 06:30 PM
jafir's Avatar
Is the red LED that is in the gauge cluster ON (or maybe flashing) when this happens? If so you car is not turning the alarm off (or perhaps turning it back on) when you get in it.
If everything is ok there, you probably need to see if you are getting power down to the starter solenoid when you try to crank and it doesn't crank.
Old Oct 8, 2012 | 06:35 PM
hawken89's Avatar
4th Gear
thanks jafir. no alarm on the truck.
i will check out the later
Old Oct 8, 2012 | 06:37 PM
jafir's Avatar
They all have alarm.
Old Oct 8, 2012 | 06:46 PM
hawken89's Avatar
4th Gear
ahh sorry yes, i forgot. my keyfob died long long ago so i forgot i even had one!
could this be the problem even though i haven't used the alarm in about 4 years?
Old Oct 8, 2012 | 06:51 PM
jafir's Avatar
It's possible. I've heard stories of the driver's door lock actuator acting up, keeping the key from disarming the system. I've also hear even weirder stories of the the actuator going bad so that when you shut the door, it arms the system again. That why I was asking about the red LED... if not... you've probably got something easier to fix.
Old Oct 8, 2012 | 11:29 PM
jfall's Avatar
Repair the key fob.
Get a battery back into it.
Go out and sync with the truck and take the locks up and down and all that.
Can't hurt.
Old Oct 20, 2012 | 04:09 PM
bink1109's Avatar
Any update?!? I am experiencing the same exact thing, and it is driving me crazy!
Old Nov 23, 2012 | 06:20 AM
hawken89's Avatar
4th Gear
Yep...needed a new starter bc my gaskets are leaking oil into/onto it.
Works great now
Old Nov 23, 2012 | 09:45 AM
Michael M. Koch's Avatar
Opened up my key fob, the battery and several other small parts fell out. Is it possible to obtain and reprogram a new one without financing a service manager's new boat?
