2002 4.0 or 4.6?
Old 09-24-2014 | 03:31 PM
ImQuattro's Avatar
Cool 2002 4.0 or 4.6?
Working on my neighbors 02 D2 (post-facelift but fogs under bumper and single bulb style headlights -not the 03/04 style headlights).
Typical HG issues.
Pulled apart, HG failure on RH bank, rear, into coolant jacket.
Originally thought this was a 4.0 motor, but it's identical to my '04's 4.6 (minus the SAI) -so I just figured I was wrong and that it was indeed a 4.6.
Got confused when the crank says 4.0 on it and repair info & parts info only show a 4.0 for this year.
SO: how do I know whether it's a 4.0 or 4.6?
Emissions sticker under the hood claims 4.6... typically that's what I go with.
Looks like a 4.6, stickers says 4.6, crank says 4.0, repair info (ShopKeyPro) and parts look up (PartsGeek, NapaProlink, ebay) claim 4.0.
WHAT IS IT??
Thanks guys!
Old 09-24-2014 | 03:36 PM
acamato's Avatar
03 and 04 are post facelift. They have the 4.6. 99-02 have the 4.0.
The 4.0 and 4.6 are the same except the crankshaft, rods and pistons. I dont think you can tell from the outside.
Check the VIN.
Old 09-24-2014 | 06:04 PM
RicketyTick's Avatar
Typical HG issues.
WHAT IS IT??
Thanks guys!
If it has 4.0 on the crank it is a 4.0 now regardless of what it started life as.
Old 09-24-2014 | 06:16 PM
ImQuattro's Avatar
What's it take to make a 4.0 a 4.6?
Old 09-24-2014 | 06:37 PM
4.6 crank, rods and pistons the 4.6 cam is supposed to be a little better.
Old 09-24-2014 | 07:18 PM
ImQuattro's Avatar
Is that all?
Engine management is the same? Seems too simple.
What's the catch?
Old 09-24-2014 | 07:27 PM
abran's Avatar
4.6 block. I thought they were interchangeable, but seems not so.
Old 09-24-2014 | 07:30 PM
Is that all?
What's the catch?
That's it, everything will work if you use all of the other parts from your existing engine. Engine management will plug and play.
4.0 had a ZF 4HP22 transmission and 4.6 had ZF 4HP24 but plenty of people have kept the 22 trans.
Old 09-24-2014 | 07:49 PM
Why do you think? I hope you're wrong...I'm building one now.
Old 09-24-2014 | 08:37 PM
ZGPhoto's Avatar
They look identical, it's a 4.0. Better engine TBH
Quick Reply: 2002 4.0 or 4.6?
