2002 Disco Headlight Upgrade in Houston TX
#31
#32
Also installed the auxbeam H4/9003 on our 2002 from Best’s recommendation, they work well and are a big improvement. Just keeping my eyes open for a cheap DRL relay.
#34
#35
The D2 Electrical Library says that the driver's side low beam + should be blue/pink, and the negative should be black. Passenger side should be blue/black and black. Driver's side high beam is blue/gray and black; passenger is blue/orange and black.
Or you could just use a DMM to test for voltage.
#36
Thank you for the wire color ID info. I cannot use a multimeter currently. The truck is undergoing a big overhaul and pretty much everything is disconnected. I decided to swap out my lights as Im waiting on some other parts to arrive and had nothing else to do. Those wires are at the plug. I need to know the polarity of the two wires that connect directly to the actual headlight bulb though.
