2002 Disco II - fuel line/filter problem?
Old Oct 14, 2013 | 08:27 AM
dillhole's Avatar
Default 2002 Disco II - fuel line/filter problem?
I tried to start my truck this morning and it didn't start. I had not driven it much in the past week, because I was on vacation, and no driving at all in the last 4 days I think. Anyway, I assumed it was probably the battery, so I get the AAA guy out to my place to give me a jump. He shows up and hooks up his battery diagnostic gadget and says its not the battery. He asks me to try and start it, and he says it is probably something preventing fuel from getting to the spark plugs.
The last time I had driven it, there were no signs of impending doom, and the two little lights that flash when the battery is starting to die were not flashing.
The starter sounds fine as far as I can tell.
I did the head gaskets a little less than 3 years ago. Battery is a little less than 2 years old.
I am fairly comfortable working on this truck, but I am now a medical resident, and I simply don't have the time.
Any ideas? Fuel line/filter? Or something else it could be?
Thanks!
Old Oct 14, 2013 | 08:31 AM
D2's do not have in-line fuel filters./ Do you have any fault code numbers if so what are they?
Old Oct 14, 2013 | 08:34 AM
dillhole's Avatar
No fault code
Old Oct 14, 2013 | 08:36 AM
Have you reset the enirita switch on the fire wall. have you ever replaced your crank position sensor?
Old Oct 14, 2013 | 08:43 AM
dillhole's Avatar
I have done neither. Where is the crank position sensor located? Is it easy to reach?
The inertia switch would just be a fuse, right? Pull and replace?
Old Oct 14, 2013 | 08:45 AM
Send me your number and I will be glad to walk you thru what to do.
Old Oct 14, 2013 | 08:49 AM
dillhole's Avatar
Done.
Luis Lujan
Nov 30, 2014 12:51 PM
bwilliam
Sep 10, 2012 04:45 PM
TC.kenya
Defender
Jul 10, 2011 01:56 AM
JerrodSteph
Jun 12, 2011 06:04 PM
roverohio
Nov 5, 2010 08:27 AM
