2002 discovery stalls when coming to a stop
Old 11-22-2014, 06:57 PM
rolandroy's Avatar
6th Gear
Default 2002 discovery stalls when coming to a stop
My wifes 2002 land rover discovery has the tendency to stall when it comes to a stop. Sometimes the idle will drop and come back without stalling, but generally it will completely stall. If we put the truck in neutral it won't stall or drop idle. It's been pretty well taken care of, reg oil changes and what not, 135,000 miles. No CEL to indicate a problem. I took it to a mechanic around here and they said they pulled an engine code that said "NA Permanent volt supply fault" and a few transmission codes that said "21 - can message MDIND invalid FTLMES" "25 - can message TANS invalid Ffh" and "20 - gear ratio monitor fourth gear". I'm lost and can't find much information about those trans codes. Any ideas?
Old 11-22-2014, 07:22 PM
jafir's Avatar
That 4th gear ratio sounds like a bad or dirty MAF.
The other descriptions don't make sense to me, we'd need the industry standard P0 and P1 codes.
Old 11-22-2014, 07:25 PM
rolandroy's Avatar
6th Gear
The truck has a new maf, crank sensor, intake tube, spark plugs, and spark plug wires all less than 1000 miles.
Old 11-22-2014, 07:28 PM
jafir's Avatar
Do you have a scanner than can read live data?
Old 11-22-2014, 07:29 PM
rolandroy's Avatar
6th Gear
I do but it is currently in the shop I can swing by tomorrow and hook up anything in particular to look for?
Old 11-22-2014, 07:43 PM
rolandroy's Avatar
6th Gear
P0734 p1884 have the same description for the two letter trans codes.
Old 11-22-2014, 07:52 PM
jafir's Avatar
That 4th gear ratio code is almost always maf. Does it come back after clearing?
Old 11-22-2014, 07:54 PM
jafir's Avatar
I'd be looking for things that affect idle, such as tps, and road speed.
rolandroy's Avatar
6th Gear
I'll check tomorrow and let you know
Old 11-22-2014, 08:26 PM
Alex_M's Avatar
What brand was the new MAF? If it's anything but Bosch or OEM then it's probably no good. Trust me, been there.
Quick Reply: 2002 discovery stalls when coming to a stop
