2003 D2 Parking break Adjustment cable
Old Jun 16, 2021 | 12:05 AM
Jon.P's Avatar
Default 2003 D2 Parking break Adjustment cable
Whats the deal with adjusting the parking brake cable? Yes I have read the RAVE on how to do this but it is not constant with whats actually in my D2. Attached is a picture of what the RAVE says to adjust and then there is a picture of the actual cable that is installed. There is some kind of rubber mount on top of the cable and no Threaded sleeve or Adjuster wheel.
I have adjusted the brake shoe by adjusting bolt until brake drum is locked and then backed it off but this still leave to much play in the line and I have to crank the parking lever all the way up (5-6) clicks in order for it to engage.
***Update***
Here is an actual picture underneath where the cable is coming out of the body
Old Jun 16, 2021 | 05:10 AM
redwhitekat's Avatar
try tight the adjuster on the transfer case
Old Jun 16, 2021 | 05:13 AM
I know when I put a 00 cdl case on my 03 that cable you show didn’t fit in the parking break hole in my 03. I think I had to drill hole bigger and adjust it as well on the transfer case
redrover75
Mar 6, 2021 12:10 PM
nevillusa
Jan 7, 2020 12:04 PM
Barnettz
Sep 5, 2013 03:07 PM
mx468
Oct 6, 2012 02:04 AM
houstonhelix
Mar 16, 2008 08:54 AM
