Hand Brake, E Brake Adjustment
Old Mar 5, 2021 | 08:03 PM
redrover75's Avatar
Default Hand Brake, E Brake Adjustment
Is it reasonable to simply adjust the brake itself, the 17mm bolt, with out lifting the truck to check clearance? Mine pulls up pretty far and if I tighten the bolt a modest amount, drive it listening for rubbing, wouldn't that suffice to with out lifting the entire truck?
Is there an easy way to tighten it up a bit?
Old Mar 5, 2021 | 08:52 PM
Best4x4's Avatar
I have better results adjusting the nut under the ebrake handle itself, but that's just me. If you look up from under the D1/D2 you'll see the threaded nut on the cable. It will remove or add slack to the cable depending on how you adjust it.
Old Mar 6, 2021 | 02:44 AM
JUKE179r's Avatar
+1 for how @Best4x4 mentioned.
You don’t have to make the e-brake cable totally taught. I used a pair of pliers and pulled hard on the end of cable and tightened the 13mm nut. After that I couldn’t get the gear shifter back into Park after driving. I had to go back under and give the e-brake cable a mm of slack.
Worked fine after that.
Old Mar 6, 2021 | 12:10 PM
redrover75's Avatar
Thanks, ill give that a go
Broken08
Oct 22, 2019 10:58 PM
Rover Newbie
Jul 9, 2015 06:00 AM
UpChuck
Aug 20, 2010 09:41 PM
ArtemZ
Jun 29, 2008 03:04 PM
Arthur
Nov 4, 2006 06:52 PM
