2003 disco driver seat wiggle
My discos drivers seat has a slight movement ( about a 1/4 inch ) when I step on the gas. It is a front to back movement. I looked under the seat and the bottom rail is firmly planted. It is the top bracket , frame that seems to move . I can't find any adjusments or loose screws. Any advice?. Thanks in advance.
My 03 had the same issue.The seat has twoHorz. shafts that run left to right and have a bolt in the ends. These bolts are loose making your seats "wiggle". They are very hard to get to unless you take the seat out but possible. The fix, you will need to move the seat up with the switch and looking from the back seat, you should see the bolts (the left side is harder to get at).Then you will need to back the bolts out alittle more and apply a drop of loctite and retighten. That should do it.
you are wonderful!!
Once I get mine outta the shop, hopefully today, I will do that!!
So.. are these bolts on the seat it's self, or on the floor??
If you could get a picture, that would be FANTASTIC!!
thank you so much again!!!
John-Robert
btw..what is loctite?
John-Robert
on
1 Post
btw..what is loctite? Loctite is the name of a liquid product that you apply to bolts that you want to stay tight. The liquid hardens and keeps the bolts in place. You have different degrees of hold. Any hardware, speed shop or even Wal-mart should carry it.
