2003 disco missing, dying at 65 mph
Old Apr 29, 2007 | 10:52 PM
sledmaker's Avatar
5th Gear
Default 2003 disco missing, dying at 65 mph
Intermittent problem, Has anyone encountered this?
Temp 75.[/align][/align]Winds from passenger side 15-20 mph. Windows and sunroofs open except drivers window closed.[/align][/align]Speed 65 mph, steady.[/align][/align]1/4 tank fuel.[/align][/align]Engine temp at middle of gauge.[/align][/align]65,914 miles.[/align][/align]Had been driving 20-25 minutes when car began missing, running OK for 30 seconds, then missing again, repeating this for a few miles until we rolled up all windows and closed sunroofs. Then *seemed* to be OK.[/align][/align]Gail opened front sunroof and car died almost immediately, would not restart. Pulled to side of road and tried unsuccesfully to restart. Starter spun engine normally.[/align][/align]Sat 5 minutes with hood open, then car restarted, ran perfectly remaining 20 miles home.[/align][/align]Check engine light not on.[/align][/align]The fuel pump, crank sensor, battery and battery cables were replaced last fall.[/align][/align]Surely I can't be the onlyowner with this problem. Help, friends![/align]
Old Apr 30, 2007 | 07:23 PM
Aquaholic's Avatar
Default RE: 2003 disco missing, dying at 65 mph
I just drove ~1,000 miles this weekend including some crazy off road stuff - not a hiccup all weekend.
'03 w/ 44,000 miles.
Old May 1, 2007 | 05:08 AM
Randy Lover's Avatar
my disco allways maxes out at 70 lol
Old May 1, 2007 | 11:17 AM
Randy, you need to do something with your truck if 70 MPH is all she has got. With my 4:11 gears and all the mods I have made on my 99 D2 I can still hit 100 on a level road.
What up with yours?
Mike
Old May 1, 2007 | 11:25 AM
Sledmaker,
You have an unusual issue going on with your truck, I don't see how the sun roof/ window positions can have any effect on the engine management. I would like to give you some feed back and I am drawing a blank.
Mike
Old May 1, 2007 | 05:00 PM
wvcox1's Avatar
Could be the fuel filter, since you're @ 65 with not much drag, then the windows being opened introduce a lot of drag, which puts more load on the engine to maintain the speed, which means more fuel is required, but if the fuel filter is clogged fuel can't be delivered properly, then the engine dies. Just a guess, & a cheap possible fix so if you haven't replaced the filter then that might be a good thing to start with...
Best of luck!
Walter
Old May 8, 2007 | 04:12 PM
mike, its an 03 standard Disco XS. on the motorway, flat, level ground, at around 70 the revs are high and you can tell shes struggling. i expect it would reach 75-80 if pushed hard enough. any thoughts ?
Old May 8, 2007 | 06:22 PM
discoBunit's Avatar
Hello,
Pardon me if I budge into this one. I'm in the market for 2003 Disco SE and alarmed to have read that 70mph is the max speed on this vehicle? Is my interpretation of what I've been reading incorrect?
Old May 8, 2007 | 08:15 PM
StevenDiscoII's Avatar
There must be something wrong with Randy;s Dicsco. Just about 2 weeks ago I was down south in Mexico I had my 2000 with 111K miles showing 115 MPH. [sm=smokin.gif]
Old May 8, 2007 | 11:03 PM
Aquaholic's Avatar
My 03 SE will cruise at 100 easy - it's tough on gas though.
Cruises at 85-90 and gets 15 MPG.
