2003 Disco starving for fuel?
Old Aug 20, 2016 | 05:20 PM
  #61
MyIQisLow's Avatar
Only if it has been running with wires mixed up for the several thousand miles when I replaced plugs, and I was careful, and tagged the wires with masking tape, and marker to make sure they went back on where they came from. I pulled the relay, and checked for voltage, and didn't get a reading. What sensors cut power to the pump? Assuming it is a sensor.
Old Aug 20, 2016 | 05:33 PM
  #62
disc oh no's Avatar
The CPS would send a signal to the computer telling it to turn on the injectors, fuel pump and coils when the key is first turned on, or when cranking. There should be power on two of the pins for the pump relay if the key is on. Do you have power at the fuse with the key on? If not, I would take a look at the ignition switch and wiring.
I didn't think the wires would be messed up. I'm just trying to think of all possibilities.
Old Aug 20, 2016 | 11:41 PM
  #63
MyIQisLow's Avatar
You mean at the relay? Or the fuse itself? Have not checked there yet, but I did check the relay. Will check at the fuse tonight.
Old Aug 21, 2016 | 06:42 AM
  #64
disc oh no's Avatar
I would check the fuse first. If there's power on both sides of the fuse, then check the power at the relay. I think the ignition switch sends power through the fuse, to the relay when you turn the key on and the ECU commands it on for a couple seconds to prime. Then when you crank the engine, the ECU commands it on again to maintain fuel pressure.
Another thing you can try is to turn the key to the on position and wiggle the key. If it makes a connection, you should get power to the pump fuse.
Old Aug 23, 2016 | 03:16 AM
  #65
MyIQisLow's Avatar
Ok. Power to the fuse, and relay, but none at the pump. I was using my test light, because I didn't have my multimeter with me, will check with that tomorrow to be sure on voltage.
Old Aug 23, 2016 | 04:00 AM
  #66
disc oh no's Avatar
If it lights the test light, the voltage is good. So you tried jumping the load side of the relay, I assume? And still got no voltage at the pump?
Old Aug 23, 2016 | 04:33 AM
  #67
MyIQisLow's Avatar
Not sure what that means. How do I do that?
Old Aug 23, 2016 | 07:52 AM
  #68
MyIQisLow's Avatar
I pulled and tested the relay again, and had no resistance once the circuit clicked closed.
Old Aug 23, 2016 | 09:14 PM
  #69
disc oh no's Avatar
What I mean by jumping it is, you would have to remove the relay and jump the pin with power to the wire out to the pump. On most standard type relays, you would jump pins 30 & 87. The relay should be marked.
Old Aug 24, 2016 | 03:41 AM
  #70
MyIQisLow's Avatar
Ok. Not sure what the deal is, but I jumped across the switch on the relay, nothing. I hooked across power to the side of the switch with the pump on it, and it started. I pulled the wire, and put the relay in quickly, and it stays running, and energizes the pump before starting like normal again now. Back to what is probably the maf problem.
