2003 Discovery died once, hot restart problem
Old Jul 28, 2006 | 10:07 PM
sledmaker's Avatar
5th Gear
Default 2003 Discovery died once, hot restart problem
I got tired of the troubles with my 99 Disco 1, so I bought a 2003 Discovery with 40K on the odometer. One week later, it died while driving on the expressway - all lights worked and the starter spun th engine easily, full tank of 93 octane gas, 92 degrees out. About 15 munutes later it started and ran perfectly. One week later, we drove the car for about 4 - 5 hours, 82 degrees out, shut it off and came back 15 minutes later. The starter spun the motor easily again, but no fire. A guy listened for fuel pump noise while I was trying to start it, but didn't hear anything. Opened the hood, waited about 15 minutes and it started again. Next day, same problem. Took it to the dealer who has tried unsuccessfully to duplicate the problem, so they can't fix anything. Does anyone have any insight on this? I am heartbroken. I can't be the only 2003 owner with this problem. Does anyone know the number for the District Service Manager for Chicago? I love the car except for the fact that I can't drive it.
Old Jul 29, 2006 | 12:31 AM
Brad S1's Avatar
Default RE: 2003 Discovery died once, hot restart problem
I only have experience in the realm of 98's, but you should check your fuses then grounds. In my experience weird little issues like that on any car have something to do with either a hurting fuse or ground.
Old Jul 29, 2006 | 11:12 AM
Were there no check engine lights?
I have never heard my fuel pump, they only run for a couple of seconds when you first turn the key, then they shut off till the engine starts.
Could be the pump, I would also look at the coil packs for failing. Do you have fuel pressure, how about spark?
Mike
Old Jul 31, 2006 | 09:54 PM
rinmud's Avatar
crank angle senser is taking a s--t normal about this miles
bennycisco
Aug 15, 2014 11:38 AM
bennycisco
Aug 14, 2014 09:00 AM
dschloe
Aug 21, 2008 10:27 AM
VermontRoverGal
LR2
Dec 3, 2007 12:53 PM
trailhead4x4
May 25, 2005 08:48 PM
