2003 Discovery Engine Problem where do I start.
Old May 19, 2010 | 03:40 PM
fishhawk's Avatar
Default 2003 Discovery Engine Problem where do I start.
I have a 2003 Land rover discovery . I have used this forum before for expert help with issues and you guys have been a blessing. My problem started yesterday when I was driving home it shuttered for a second and then everything was fine. Stopped at the store and went to crank it, it turned over and over then it ran for a second. Cranked it again did the same thing but this time it stayed running. Drove it home. this morning same problem left it at the house. No lights warning lights. What things can I check first. Could it be a Fuel filter if there is one, Plugs,Fuel Pump? Other than this it runs great. I have one hundred and ten thousand miles. Thanks for any help Mark
Old May 19, 2010 | 04:36 PM
d2luvr's Avatar
sounds like a crank position sensor failing to me.
Old May 19, 2010 | 05:30 PM
audiS4S6's Avatar
I concur with the CPS. A fuel filter will show up when trying to accelerate - not at idle or start up.
Old May 19, 2010 | 07:03 PM
fishhawk's Avatar
crank position sensor...Is this something I can fix on my own.
Old May 19, 2010 | 07:55 PM
03discoman's Avatar
yes it is a CPS...
its easy to change...
-jack the truck up on ramps
-crawl under and remove the cover for the CPS
-remove sensor and swap in another ..(i have a good CPS i can sell to you)
reverse the steps...
you really need to get the RAVE manual..... infact do this first....
dmatranga
Feb 5, 2013 12:27 AM
armyeng
Mar 8, 2011 05:58 PM
carlvanceanderson
Oct 13, 2010 08:58 PM
R0V3R
Oct 26, 2009 02:51 PM
