2003 discovery, keep burning a 10amp a/c fuse
Old Jan 8, 2011 | 06:08 PM
mydisco03's Avatar
Default 2003 discovery, keep burning a 10amp a/c fuse
A/C fuse keep getting toste on my disco, I tray to narrow the problem by disconecting the blower and a/c compresor and fan, and when i put a new fuse it burn..... I check the black and red wires that goes to the blower and it looks fine, no smell at all. and if I put a 20 amp fuse i will burn it afther 5 min.... HEEEEEEEEEEELP
Old Jan 8, 2011 | 10:01 PM
disc oh no's Avatar
Does the fuse blow out immediately or, just when you actually turn a/c ON?
Old Jan 9, 2011 | 10:40 AM
If you have never tried tracking down a short or damaged wire harness, you need to quit replacing the fuse, causing more damage, and get it to a good qualified mechanic.
Old Jan 9, 2011 | 12:23 PM
mydisco03's Avatar
It don't matter if the a/c is on of off, I just put a new 10amp fuse and boom, gone.... once i put anotherone boom. But it's been getting worse and worse, about a year ago she star doing this, and i did put a 15amp fuse and after 6mont blown that one, then i put a 20 amp fuse and once againg blown that one too. so now i need to fix's this before it damage something else......
Old Jan 9, 2011 | 12:42 PM
lordmorpheus's Avatar
You replaced a fuse that was originally 10amp, with a 20amp? You should NEVER do this! The fuses are there as a safety: they are designed to blow when a problem is present in that circuit. They blow before the excessive current takes out something more expensive than a $0.25 fuse.
Time to break out RAVE, find the the wiring diagrams, find out what all is in that circuit, and check every wire for a short to ground, or short to power.
Old Jan 9, 2011 | 03:42 PM
mydisco03's Avatar
Yup the rave will be my best bet!!!! Thanks guy's !!!! I will keep you post with pic's and videos in the next few days....
Old Jan 9, 2011 | 04:12 PM
disc oh no's Avatar
yeah, not good to just keep burning fuses and NEVER a higher amp fuse, that will do some serious damage!!! You should track it down, then fix it then try another fuse. Sounds like a definite short. In my experience, when you find the cause of the short you'll know it. Fix what's wrong, replace fuse, THEN add a new fuse. In other words wait until it's fixed and tested before trying a new fuse, better than doing more damage... or lighting a fire!!! Good luck man.
Old Jan 10, 2011 | 03:27 PM
mydisco03's Avatar
Thanks !!! =D
Old Apr 12, 2011 | 03:17 PM
mydisco03's Avatar
Well I found out why I keep burning the a/c fuse..... It doesn't matter if the a/c was switch to on position or off.... Turns out that the left side vanity mirror light switch broke and the light stays on for about 2 years and because it's a small light I never noticed it.... This light raises up the tempeture on the small wire harnes ending up melting and toasting the sun visor light, causing the fuse to burn with out turning the a/c on..... End of story.
blaster1232
Jul 13, 2015 04:37 PM
gillart
Jan 7, 2015 07:12 PM
fishEH
Jan 5, 2014 10:36 AM
Blakesrover
Feb 21, 2013 01:43 AM
adwarren78
Sep 26, 2010 07:59 AM
