'08 LR3 Fog Lights Keep Blowing Fuse
Old Jan 4, 2015 | 02:49 PM
gillart's Avatar
Default '08 LR3 Fog Lights Keep Blowing Fuse
Hey Rovers. I just bought a used 2008 LR3 and the fog lights won't turn on. I changed the fuse and they worked for about 12 hours then went out again.
Might this be a common issue/fix? I bought it from a Buick/GMC dealer who is about to go in looking for the issue which makes me nervous. I wish they would just send it over to the Land Rover dealer to fix...
Thanks.
Old Jan 4, 2015 | 04:16 PM
TOM R's Avatar
Harness runs behind the bumper skin, plug in behind pass headlight if that helps
Old Jan 5, 2015 | 08:39 AM
bbyer's Avatar
Default Common issue, simple fix.
Remove both fog light assemblies and then look at about the first foot of harness attached to the back of the light.
If there is enough slack in the harnesses, you will find one of the lengths with the insulation rubbed off and an exposed conductor.
The cable rubs on something metal and sharp behind. Land Rover did not provide enough cable support or part of the bumper behind has a sharp cutting edge the conductor grounds to and hence the fuse blows.
In the newer 3's and 4's, LR provided more support and protection of the harness.
Old Jan 5, 2015 | 08:58 AM
TOM R's Avatar
To remove fog light trim ring pulls out then unbolt the lens
If you need to remove the bumper cover it is very involved
Old Jan 7, 2015 | 02:36 PM
gillart's Avatar
Looks like that was it, bbyer! Thanks. The dealership reinforced it and now the lights stay on - hopefully for good.
Old Jan 7, 2015 | 05:23 PM
TOM R's Avatar
Great to know, if someone does this with pics I can sticky it
Old Jan 7, 2015 | 06:19 PM
houm_wa's Avatar
Another sticky? There are now so many stickies that you have to scroll WAY down just to see new posts. You may consider un-sticking some of the current stickies!
Old Jan 7, 2015 | 06:56 PM
bbyer's Avatar
Default perhaps a subsection required
I tend to agree re the stickys comment above.
It is probably better to create a subsection titled something like Solutions and Procedures to Recurring Concerns.
Otherwise, it will only be a matter of time until we will have to open on the second page to find new threads - probably not ideal either.
Old Jan 7, 2015 | 06:59 PM
bbyer's Avatar
Default thanks for the update
The odds are they found the problem and solved it. We always appreciate feedback as to how events were resolved so Thank You. The GM dealer also learned something as well.
Old Jan 7, 2015 | 07:12 PM
TOM R's Avatar
YEAH YEAH YEAH, I HEAR YA, I do most stuff on my tablet had to break out the laptop to get it all condensed like the d1 section is, you were reading my mind, but hey what do you want for free labor?
fishEH
Jan 5, 2014 10:36 AM
cevans03
Sep 25, 2012 11:31 AM
mbeasom
Apr 26, 2011 10:35 AM
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
gublom
May 2, 2007 11:57 AM
