2003 Discovery rear wiper arm "spring" ...HELP!
I replaced the rear wiper arm but now I have a new problem.
OK, so I removed the spare tire on the back to get to the wiper assembly. The rear wiper arm is now replaced, I tested it and...the wiper does not sit flush with the rear window. I noticed that on the washer fluid line there is a "spring" with a curled hook at each end. I assume that is to keep the tension on the wiper arm so the wiper blade will sit flush against the rear window.
But, I do not see where to hook these "spring" hooks? Anyone help me out here? I'm in my cold driveway and I'm running out of sublight. A drawing or schematic would be even better.
Thanks guys, as always----
Kurt
Kurt
hilltoppersx
09-22-2010 07:44 PM
