2003 Discovery rear wiper arm "spring" ...HELP!
Old Dec 23, 2009 | 04:28 PM
kpl1228's Avatar
Default 2003 Discovery rear wiper arm "spring" ...HELP!
I replaced the rear wiper arm but now I have a new problem.
OK, so I removed the spare tire on the back to get to the wiper assembly. The rear wiper arm is now replaced, I tested it and...the wiper does not sit flush with the rear window. I noticed that on the washer fluid line there is a "spring" with a curled hook at each end. I assume that is to keep the tension on the wiper arm so the wiper blade will sit flush against the rear window.
But, I do not see where to hook these "spring" hooks? Anyone help me out here? I'm in my cold driveway and I'm running out of sublight. A drawing or schematic would be even better.
Thanks guys, as always----
Kurt
Old Dec 23, 2009 | 07:38 PM
kpl1228's Avatar
still standing by...thanks
Old Dec 23, 2009 | 08:23 PM
Sorry I cant be of more help but there will be hooks on each end where the spring goes too.
Look at the old arm and see how the spring attches.
You can also look at your front arms to give you a idea.
Old Dec 23, 2009 | 08:25 PM
mwindth's Avatar
Check the RAVE (Land Rover Service Manual): http://landroverresource.com/
Old Dec 23, 2009 | 10:04 PM
kpl1228's Avatar
Default manual
I did not know about the link for the repair manual --thanks much.
KL
94svt50
Apr 27, 2012 02:49 PM
Wittefish
Jul 13, 2011 04:53 PM
Disco Mike
May 4, 2011 07:08 PM
hilltoppersx
Sep 22, 2010 07:44 PM
jdelp
Feb 20, 2008 10:11 AM
