2003 Discovery will not start after replacing the Battery
Old Nov 17, 2021 | 08:28 PM
humair's Avatar
Default 2003 Discovery will not start after replacing the Battery
I have a 2003 Discovery, Car has been parked for around 3 moths, jump started in first attempt. left it running for about an hour, turned it off, it will not start. had the battery replaced by AAA, no change. Any one know what I am suppose to do.
Old Nov 17, 2021 | 10:46 PM
greisinb's Avatar
Start with the simple thing first, is the battery connected correctly and tightly? The lugs on the battery cables aren’t the best, I have to use shims on mine for a good connection. Can you clarify “will not start?” What exactly happens when you turn they key- any dash lights or clicks? Does it crank?
Old Nov 18, 2021 | 05:53 PM
04disco2va's Avatar
Greisinb is correct. May not be your issue but had the same situation happen to me and overlooked that the clamps needed shims because they wouldn’t get tight. Actually replaced with better clamps.
Old Nov 18, 2021 | 08:49 PM
humair's Avatar
“will not start”, what I meant is that engine will not crank, dash board lights up. It has a new battery. I am thinking if dashboard lights up, that is indicator that battery has a good connection
Old Nov 18, 2021 | 09:00 PM
Best4x4's Avatar
All about AMP's, just because the dash lights up doesn't mean the battery terminals are secure or good enough to carry the necessary AMP's down to the Starter.
Old Nov 18, 2021 | 11:16 PM
Xanthro's Avatar
The default battery lugs are a weird size and often cannot tighten down enough to start the vehicle without shims. If AAA didn't put on shims, you can see dash lights but the vehicle won't turn over.
I actually cut my lugs and replaced them with military style ones.
Old Nov 19, 2021 | 03:45 AM
JUKE179r's Avatar
+1 to this. Best mod I could have done. Cheap cost, great connection to battery and looks good.
Old Nov 19, 2021 | 07:17 AM
B Strife's Avatar
Is the little red light on over the steering column? I occasionally have an issue where I have to lock and then unlock the doors using the keyfob to get the ignition to work.
Old Nov 19, 2021 | 10:22 AM
greisinb's Avatar
This happens to me as well (when my connection is poor),a bad connection will allow enough electrons through to power the low power electronics and LED's but not enough oomph to crank the starter motor.
Old Nov 20, 2021 | 04:54 AM
The Deputy's Avatar
Yep, takes roughly 175/250 amps to crank a starter over. Whereas, the cluster/dash lights draw about 20 amps.
Changing terminals ends is such a pain on these things, neg cable gives you nothing...as far as extra cable, since it is bolted to the fender bracket and barely reaches neg post to begin with. Then the double positive makes things difficult also.
