2003 Discovery will not start after replacing the Battery
Old Nov 20, 2021 | 07:08 AM
mln01's Avatar
You can even shim the battery clamps with a toothpick. I've done it. I've also run a very small screw into the gap between the battery post and the cable terminal. Another trick is to squeeze the cable terminals slightly with a pair of Vise Grips to deform them from round. Any of the three methods can work to help ensure a better connection to get enough current (amps) to the starter.
Old Nov 24, 2021 | 08:48 PM
greisinb's Avatar
Originally Posted by Xanthro
I actually cut my lugs and replaced them with military style ones.
Thanks for this little mod/improvement. I ordered a set and installed them this afternoon, it’s such a better fit and a nicer look!
Old Nov 25, 2021 | 10:51 AM
Xanthro's Avatar
Changing terminals ends is such a pain on these things, neg cable gives you nothing...as far as extra cable, since it is bolted to the fender bracket and barely reaches neg post to begin with. Then the double positive makes things difficult also.
Which battery you choose can make a difference, but an advantage of the military style connections is that they extend the length of the cable. The clamp is a separate piece with double attachments at the end, then you crimp on large lugs to the wires. You'll actually have more wire reach than when you started.
RizzleKicks
Nov 7, 2021 10:19 PM
Luna89
Freelander
Feb 20, 2021 04:16 PM
bracketd
Apr 3, 2013 03:54 PM
Carguy
May 24, 2012 03:33 PM
rufrov
Feb 1, 2010 06:21 AM
