2003 Land Rover SE
Old Dec 18, 2011 | 03:28 PM
highred's Avatar
5th Gear
Default 2003 Land Rover SE
I am considering to buy a 2003 Land Rover SE with 147K miles. I would like to know what issues I should ask about and any concerns there should be about this vehicle. Thanks in advance! Rob
Old Dec 18, 2011 | 03:54 PM
jafir's Avatar
There is a write up section at the top of the page, it includes a "buying" section near the bottom. Read through some of that.
A lot of people are going to warn you about a possible oil pump issue with the 03's. You'd be wise to look at the VIN and see if your VIN is in the bad oil pump range, but with the miles that this 03 has on it, I'd personally not worry about it. It would have blown up LONG, LONG ago if it was bad and not repaired or replaced. But maybe you can use it to haggle.
marrtial
Feb 9, 2013 08:17 AM
dmac
May 23, 2012 10:23 PM
sloppyjoe
Oct 11, 2009 10:43 PM
toddde
May 12, 2005 06:31 PM
