2003 overheating lower rad hose cool?
Old Jul 31, 2013 | 10:20 AM
sickws6's Avatar
You guys are great!
Old Jul 31, 2013 | 08:42 PM
sickws6's Avatar
Checked my fan it does feel like peanut butter when warmed up and will not freewheel when try to spin it also air is flowing in correct direction through radiator towards engine so strong in fact can hold cardboard up to the grill. The bottom hose is actually not even getting warm it feels like. I wonder if PO put some additive in it and clogged it up.
Old Aug 1, 2013 | 01:34 PM
sickws6's Avatar
I might just rip the radiator out to check it out.
Old Aug 1, 2013 | 04:52 PM
jfall's Avatar
If you can't hear the fan spin up and roar ever - like when you come off the highway and you have the foot off the gas and slow to 50 and then to 45 - my fan is roaring and pulling air with a new Hayden Fan clutch..
Cold - I had the new and the old fan clutch side by side.
The new clutch had twice as much resistance to turning.
I would replace the fan clutch.
Replace the radiator
and put in a real Land Rover 180 thermostat. Not a junk Motorad.
The other clue that things are wrong..
You come off the highway and go into a parking lot.
Your AUX electric fan is running - without the A/C on.
That means your engine is over 210 to 212F and the AUX fan is turned on by the ECU to help avoid overheating.
I don't have ANY of these issues now since replacing the three musketeers:
RAD, Thermostat and Fan clutch.
Don't miss these issues either.
I put a scanner on the OBD2 and at 75 Degrees F out -
I was running 189F down hills on the highway
205 or so in town when idling
and 190 to 195F on the interstate at 60 MPH.
Old Aug 1, 2013 | 08:47 PM
sickws6's Avatar
Did inline thermo today runs great temps steady at 180-185.
Old Aug 1, 2013 | 09:48 PM
Madlands's Avatar
Glad you got it under control I'm a big fan of the inline thermostat. I've run mine a few months now and love the results so far.
LADEROUTE
Sep 1, 2012 05:06 PM
XCELLER8
Jul 16, 2011 12:56 PM
Joseph David
Mar 14, 2011 04:04 AM
Northern Land Rover
Aug 11, 2010 08:25 PM
Roveroh
Jul 15, 2008 08:25 PM
