2004 coolant leak causing oil consumption?
Old Dec 28, 2018 | 01:26 PM
batard's Avatar
Default 2004 coolant leak causing oil consumption?
I recently discovered a coolant leak at the throttle body heater plate, which is a common thing. But it had been leaking (slowly) for a while without me noticing. I found out about the leak at a gas station, at which time it was also observed that my oil level was dangerously low. So I had them put some more oil in, limped it home and deleted the throttle body heater plate, which isn't necessary in my warm climate.
I then topped up the coolant and bled the system. Could the oil burn have been a result of the car running hot when it was low on coolant? Or is that likely an independent issue?
Old Dec 28, 2018 | 02:25 PM
Richard Gallant's Avatar
Check the passenger side oil separator, pull the hose off the valve cover my bet is it is clogged which will lead to much higher oil consumption. A bunch of carb cleaner down there, takes a 5 to 10 shots will clear it. You need to keep going with the carb cleaner until it drains down just by gravity.
back9sunday
Mar 4, 2016 11:42 AM
RoverFL
May 13, 2015 08:51 PM
ninjaff21
Apr 7, 2014 06:53 AM
Rover De Land
Apr 5, 2013 03:02 PM
tito5590805
Sep 27, 2010 11:32 AM
