2004 D2 Cylinder 2 Misfire/Backfire - Replaced all plugs wires and ignition packs
Old Sep 16, 2015 | 10:26 PM
MechHead's Avatar
6th Gear
Default 2004 D2 Cylinder 2 Misfire/Backfire - Replaced all plugs wires and ignition packs
I've been working on my D2 for a while can't seem to find a solution just started missing and backfiring out of the exhaust one day. It only happens under load and I have replaced all the plugs new magnecor wires and a new ignition pack.
Tried to find this same problem on the forums but most are fixed with new plugs/wires.
I did a compression test on cylinder 2 and it looks good throwing codes P0302 and P1319.
Also definitely cylinder two only when I unplug #2 sparkplug backfire goes away completely.
Any help is greatly appreciated.
Old Sep 16, 2015 | 11:52 PM
Dave03S's Avatar
Cam shaft failure has similar symptoms.
Old Sep 17, 2015 | 09:38 AM
MechHead's Avatar
6th Gear
Wouldn't camshaft failure show bad compression?
Old Sep 17, 2015 | 10:41 AM
MechHead's Avatar
6th Gear
well currently in the process of pulling the valve covers checked the injector solenoid fires when 12v applied at least.
Old Sep 17, 2015 | 11:59 AM
MechHead's Avatar
6th Gear
Looks like it is the camshaft didn't want to believe it but the exhaust valve on the number 2 cylinder barely moves.
Old Sep 17, 2015 | 03:21 PM
Joemamma1954's Avatar
I have seen this when the exhaust valve is burnt or not closing all the way.
Old Sep 17, 2015 | 04:28 PM
MechHead's Avatar
6th Gear
Halfway through getting the timing chain cover off, I'll post some pictures of what the camshaft looks like once I finally get it out.
Old Sep 17, 2015 | 09:07 PM
MechHead's Avatar
6th Gear
Yep number two lobe completely worn down i'm guessing it was from my wife letting it get low on oil. any suggestions on replacement camshaft lifters and push rods?
Old Sep 17, 2015 | 09:55 PM
Alex_M's Avatar
I love my Kent Sports H180, but most guys go with various Crower cams. Your push rods should be fine, I'd also go with some Rhoads Bleed Down lifters if you can spare the extra cash, they give an extra little bump at lower RPM. Also, be sure to use Diesel oil. Rotella.
Old Sep 18, 2015 | 02:49 PM
Kent and Crower, both should work great(probably cheaper than OEM). I will second the Rhoads lifters. Get a cam made for low end torque, and not high rpm power.
Be sure and follow the cam break-in procedure to the T.
