2004 Disco 2 Engine Rebuild
Just bought a 2004 Disco about a month ago. It was running rough and had an obvious blown head gasket. I figured "No big deal. I can replace a head gasket." Long story short, the block was damaged. So now I am faced with an engine rebuild which is fine except I have never done one before. So here is the general approach I am taking. I welcome any advice you might have.
Damage with gasket pulled off
Up close and cleaned off a bit
- Bare block here: https://www.roverlandparts.com/2003-...lock-4-6l.aspx
- Turner engineering flanges - install with local machine shops
- Local machine shop examine heads for warping, for valve guide wear, grind/reseat valves and seats, install new stem seals, and test the existing valve springs
- New lifters, rods, main bearing and connecting rod inserts
- New piston rings
