2004 Disco 2 Engine Rebuild
Old Oct 5, 2021 | 09:09 PM
  #471
cvhyatt's Avatar
Originally Posted by whowa004
How do you like the geolanders? and congrats on finishing a long job.
Thanks Whowa. I'm glad its done. Just hope I did everything right and nothing blows up on me while driving.
Got about 1000 miles on the Geolanders including the trip up to Uwharrie. They performed well at Uwharrie and seem to be holding up well on the highway for a mud tire. Quieter than I expected.
Old Oct 13, 2021 | 05:48 PM
  #472
cvhyatt's Avatar
Default 10/13 Update
Saw this leak. I am assuming this is an bad axle seal?
Also gearing up for some new projects in the next couple of weeks:
  1. New Catalytic converter assembly on Monday
  2. Headliner removal and recover next Friday.
  3. New paint and som minor body work the week of the 25th.
Will post pictures as I go.
Old Oct 13, 2021 | 10:02 PM
  #473
tnrangerover's Avatar
Looks likely. Since you were just in there, you know what to do!
if it’s not brake fluid, it’ll be diff fluid.
Old Oct 19, 2021 | 08:29 PM
  #474
cvhyatt's Avatar
Good news and bad news tonight:
  • Replaced the axle seal - no big deal. We'll see if that fixes the leak.
  • Loose cat element was actually not a loose element - it was a loose heat shield.
  • Clunking over bumps was actually loose rear shocks.
  • Getting misfire codes - P0300, P0304, P0303, P0306, P0305. Upon inspection i found an O2 sensor with wiring that was frayed from rubbing up against the driveshaft so I guess I will start there.
Old Oct 19, 2021 | 09:19 PM
  #475
should be an easy fix at least! These rigs are a bit like an unhappy toddler at times, aren’t they?
Old Oct 20, 2021 | 12:50 AM
  #476
JUKE179r's Avatar
Check your fuses in the engine bay.
I had an O2 sensor rubbing also. It shorted and blew the 15A fuse F2.
Old Oct 22, 2021 | 06:38 PM
  #477
cvhyatt's Avatar
Default 10/22 Update
Starting the next evolution: aesthetics. Going to get the disco painted and the headliner reupholstered. Already took it to the upholstery shop and they have it removed. I’m going to bring it by again after paint to have it reinstalled.
This weekend is all about prepping for paint. I have removed the sun roofs and the nerf bars (which were full of water!). Tomorrow I pull off the rear bumper and remove the black herculiner from the roof. Also decided to blow out the drain tubes with compressed air while I had the available.
Headliner removed
Nerf bars leaking water
One down - one to go!
Blowing out the drain tubes
Old Oct 22, 2021 | 09:15 PM
  #478
austinlandroverbill's Avatar
I went thru a rebuild 6 years ago. A little late, but here's the link to my parts list.
https://landroverforums.com/forum/di...-repair-73562/
Old Oct 23, 2021 | 09:15 AM
  #479
cvhyatt's Avatar
Default 10/23 Update
Rear bumper off. Will use the week of paint to clean this thing off, de-rust it and repaint.
Old Oct 23, 2021 | 05:48 PM
  #480
cvhyatt's Avatar
Got a good portion of the Noico in. Should be able to finish it up tomorrow. Also got all the Herculiner off the roof. One more pass with 600 grit and I should be ready to take it in on Monday
Sanding turned out to be the easiest way to get the Herculiner off.
Herculiner removed
Noico applied much easier than the Reflectix I used before
