2004 disco 4x4
Old Aug 24, 2008 | 01:30 PM
wesley64's Avatar
Default 2004 disco 4x4
how exactly does the 4x4 system work?on my dodge diesel,i engage either hi or lo range and the hubs are electrically actuated.how does a 2004 disco work with just a hi a neutral and a low?
thanks
brett
Old Aug 24, 2008 | 01:46 PM
AK Rover's Avatar
Default RE: 2004 disco 4x4
The Discovery uses a full time four wheel drive system with a center differential to allow for difference in rotation speed of the front and rear drive shafts. The 2004 model brought back the center differential lock that works like a locker in a normal axle forcing the shafts to spin at the same speed increasing traction.
jdelp's Avatar
All disco's are full time 4x4, no locking hubs. I've gotan '04, which is when they brought back the center locking diff (locks front and rear drive shafts together). So, you got hi for everyday driving, low is for off-road < 10mph and in either in the '04 you can pull the lever to the left to lock the diff.
Old Aug 24, 2008 | 10:22 PM
Your Dodge is part time 4 wheel drive, that is why it has the locking front hubs.
With the hubs unlocked the front wheels "free wheel", meaning that they just coast.
In a full time four wheel drive all four wheels are always under power.
Full time 4x4 uses gears, all wheel drive uses clutches, part time 4x4 uses a combination of the two.
eddie9879
Jul 23, 2013 10:01 PM
Tracecroft91
Feb 17, 2013 12:55 AM
nevada ben
Nov 11, 2012 10:17 AM
MuleyJ
Feb 26, 2011 12:08 AM
asmcmillin
Mar 19, 2005 12:51 AM
