2004 Disco II trouble
Old Feb 10, 2022 | 05:36 PM
  #21
zski128's Avatar
I am sure others will chime in here. Either option will work but to depends how much time vs money you want spend.
option 1, if it where me I would got that route but tear down the engine and pressure test the block and refresh it while it was out. No way I would install it as is, you could just end up in the same boat. You could also just get a known good block and swap internals over. If you can’t do this yourself see option #2
option 2, AB block is very expensive and they will only warranty if you have a shop install it. So this will be $$$ but more of a better shot of not having problems.
Edit: sorry missed the part about no cost to you. I would go the AB route in that case. If they are only giving you 30 day warranty on the used engine then it’s not worth the risk in my mind. I assume the shops liability ends for any other issues after 30 days.
Old Feb 10, 2022 | 07:10 PM
  #22
wildwilly69's Avatar
The AB option I will have to pay the difference in the cost between the used engine and the AB long block. I figure the in and out costs between the used engine and the AB long block will be a wash.
Old Feb 21, 2022 | 12:32 PM
  #23
I'm going to be replacing the engine with a 4.6 long block from AB. What else should I be replacing while the engine is out and things are easy to get to?
Old Feb 21, 2022 | 06:33 PM
  #24
Extinct's Avatar
Starter, CPS, repair all the cracked looms.
Old Feb 22, 2022 | 07:07 AM
  #25
redrover75's Avatar
Perhaps relocate the ignition coils?
Old Feb 22, 2022 | 10:33 AM
  #26
tnrangerover's Avatar
I'd recommend turner engineering instead. I know several rover-specific mechanics who will never buy an AB block again. poor quality machining. turner does it right but it ships from England as a short block.
Don Woodard
May 29, 2018 11:33 AM
robert.juric
Mar 29, 2015 11:53 PM
NT_RoverII
May 25, 2012 10:50 PM
Tayrover
Nov 1, 2011 10:21 AM
BearBait
Oct 29, 2011 07:37 PM
