2004 HSE Oil leak help!
I have a large oil leak coming from the front bottom of my 2004 HSE Discovery 2 with 140k miles. I thought it must be the front seal behind the crank/harmonizer pulley. Attached are pictures. I recently replaced that seal and just drove it around and am still having a massive leak. Everything was sprayed off and cleaned after the seal change as well.
Can anyone help diagnose?
This is during change of the seal
This is after the seal was changed and 10 min of driving around.
Post a photo of your harmonic balancer shaft OD. You may have a big groove. Also, you need to do the PCV mod. Do a search. Is the back of the balancer soaked in oil, or only the pan? A leak on the id of the seal will soak the balance and sling oil everywhere. A leak on the OD of the seal will only run down the pan.
