2004 Land Rover Discovery 2 Red Battery Light On the Dash
The red battery light came on the dash on my 2004 Land Rover Discovery 2. The truck has about 68k miles on it and was running all good before and after the battery light came on, didn't notice much difference after the battery light showed on the dash. I measured the voltage using multimeter. It's at 12.78V when the car if off, and 13.89V when the engine is idling. Same voltages at the battery terminals and the alternator connection pole. I kept driving the truct for about an hour with the battery light on, the truck worked just fine. And the voltages are about the same as I measured before.
Any idea what triggered this battery light on?
Thanks,
Thanks,
Overall, whenever something inexplicably weird happens in the electrical context, it's almost always remedied by charging the battery. FWIW, I have to charge the battery every couple months just due to how often it's driven, and it almost always needs about 50-60%. Try that before anything else?
When this happened with my truck about four years ago, it was simply because my then 23-year old son hadn't tightened the nuts for the connectors for the two wires on the alternator enough. Perhaps try removing and cleaning both of them, after first disconnecting the battery.
Sometimes connectors may get a little oxidation or something that's not really visible that prevents them from carrying current as designed. I had that problem with my first car ~45 years ago (a '65 Mustang). It wouldn't start, but I solved the problem by simply disconnecting the primary lead from the starter, scratched up the surfaces a little bit, and reconnecting it. You could get fancy and use an emery board or a little piece of sandpaper, but even just scratching around with a screwdriver or a nail may do the trick.
Try that out and let us know what happens.
BTW, the smaller wire on the alternator runs to the battery light in the instrument panel. According to the RAVE Electrical Library description, "A warning light in the instrument pack illuminates if the charging system is not generating a voltage equal to or more than the battery voltage." I'm not sure by just what sorcery that works; perhaps someone here who knows more about electrical systems than I can explain.
But yeah, check your terminals- I swapped mine out with ones that actually fit (the stock ones are terrible) and noticed an immediate improvement.
Thanks so much to greisnb for this explanation!
We are used to seeing electrical circuits terminating in a ground (earth). It’s odd to see a circuit with power supplied to both terminals of a light (LED).
Here’s my attempt at an emoji representation of how this works.
Battery 13.89v > 🤜➿💡➿🤛 < 13.89v Alternator
I depicted equal voltage on both sides because the battery and the alternator are connected.
Most of the time, there is equilibrium in the system. From where the LED sits in the system, the voltage it’s seeing from the battery = the voltage seen from the alternator. This produces a standoff, and the LED (represented here by an Edison incandescent) does not illuminate.
But, let the alternator voltage drop and current then begins to pass through the LED from the battery, thus illuminating the LED. In other words, the alternator is not producing enough voltage to battle the battery voltage to a draw (pun intended).
This may not mean the alternator is not producing any voltage at all; it means that it’s not producing as much voltage as the battery is supplying which will eventually discharge the system.
Thanks again, greisnb !!!
