2004 Land Rover Discovery
Fair enough::::::: sorry
Spike is a very good resource for information, he also has a thread describing exactly how to bleed this system. I am very surprised you did not find it while looking for a solution.
this is pretty easy but it never hurts to have a second pair of hands to help put in bleed screw:
1. with a cold engine 2. Take out bleed screw on line or T in between lines 3. remove cap on tank and un clip line from battery box 4. lift tank about 6 inches, 5. fill until you see coolant flow from the bleed screw, then insert and tighten screw 6. Put tank back into place then clip line to battery box again and fill it to the cold level line and put the cap on. 7. Start truck
8.Drive around for a few minutes just to warm up to operating temp. Park truck and let cool down 9.after truck is completely cold again open cap and ad coolant as necessary back to cold level line and you will now have your coolant system free of any air bubbles and the proper amount of coolant in the system!!!!!!! It is very important to have this system full the proper way as it is easy to have overheating problems if not. Sounds like the mechanic that worked on your truck was not aware of this procedure and just thought he could fill up the coolant tank and call it good. Not the case buddy, good luck with this. Please remember never to open a coolant cap while hot it can spray everywhere and burn you very badly.
Nothing wrong with PM's, making friends, talking on the phone, text messages etc.
The only problem comes when information on how to repair/fix something is not shared with the community.
When that happens then only those two people know the answer.
Again nothing wrong with information sharing, but please show the class how your work.
I understand that there are a few different preferred methods to bleed this system and that we all have a opinion on which way works best, and in logic more than just one of these methods will work. I am just comfortable with this method as it has worked for me when doing my coolant flushes.
Thank you everyone for your help. Especially instructions to help me out on this situation with the coolant and how to properly have the system bled. This is the first time I have had a Land Rover and love this vehicle. I am going to be working on it this weekend. So I will keep you informed. Thank you for making me feel welcomed and helping me out.
DerrickInMississippi
01-12-2008 07:49 AM
Reutdog
07-20-2006 05:40 PM
