2004 LR Discovery Windshield Wiper RELAY
Hi Folks,
I have this issue, my wipers wont work anymore. I believe that it may just be the relay as they worked in and out and eventually just stopped. Go figure they didn't work when it rained - no surprise there. Anyway, I want to order the relay but I'm really not sure which one to get?
Do I get just one or do I replace a few of them?
I'm not sure if the link will work and show the product but is this the only relay I need?
Windshield Washer Relay
Search parts by keyword - NAPA Auto Parts
Part number AR6443 Description Windshield Washer Relay Attribute # of Terminals: 4
Any Help would be appreciated!
Thanks!
Bartlomiej
Thanks!
Bartlomiej
@SavannahBuzz
I'm not good with electrical and wiring etc. What is the Stalk Switch? The Relays are the yellow boxes you plug into the fuse box are they not? I don't think they are behind the fuse panel? That wouldn't make sense if you ask me. Fuses and Relays should be easily accessible so anyone with some handy man in them can change them. Or am I wrong?
You don't take the wheel off. Just turn 90 degrees to get at the screws. It could be a fuse you have not found, like Fuse 19. It could be the relay, the IDM module, the BCM program, the stalk switch, the wiper motor.
If you can operate the flick switch and make it wipe once, then the motor and fuse are good. Here is a schematic, you might have to break out a volt meter.
Well here is exactly what happened. Basically it started acting funny.
A couple of times it worked and then didn't. Once I shut the car off 3x and tried to get it to work. At the 3rd attempt they worked again. Flick and Turn of the switch.
Now, the flick wont work and the turn wont do anything either. I did check all the fuses and they are fine. So its either the relay or the switch. But what do I know.
I will take a look at what you sent me! How long do you think the mechanic would spend on something like this?
Thanks!
Thanks!
