2004 neither shaft spinning
Old 03-23-2020, 05:34 PM
Mb6288's Avatar
Default 2004 neither shaft spinning
My 2004 disco started having the differential shifter slip out of high while driving, mainly decelerating. Then all of a sudden some terrible grinding and it wouldn’t drive. Runs fine, but put it in gear or reverse, terrible grinding sounds, and neither shaft will spin. This has to be a bad transfer case, right? Or could it be something else ?? Thanks y’all
Old 03-24-2020, 09:28 AM
whowa004's Avatar
I'm assuming you are referring to either drive shaft won't spin? Vs an axle shaft? But yes that certainly sounds like you roasted your t-case.
Old 03-24-2020, 10:37 AM
Dave03S's Avatar
When was the last time the T Case was serviced or topped up with oil? They will do this after 100k miles without service...
Old 03-24-2020, 11:28 AM
XRAD's Avatar
Easy to drain the CDL case and check for metal frags. Not so easy to fill unless you have a good pump n hose....
Old 03-24-2020, 02:51 PM
Richard Gallant's Avatar
Received 1,178 Likes on 815 Posts
Just for the future what does a transfer case service consist of ?
Old 03-24-2020, 03:55 PM
Brandon318's Avatar
And not easy to drain if you have an 03/04, haha. Still can't figure out how to get around that stupid crossbar so perfectly in the way.
Old 03-24-2020, 05:23 PM
craiglud's Avatar
Service should be checking and or changing the oil depending on mileage.
I bought one of those little water sprayers you pressurize to water plants with. Mine is 1/2 Gallon. Put the oil in the can pump it up and squeeze the trigger. I am going to do the same thing with the transmission oil service.
Richard Gallant (03-24-2020)
Old 03-24-2020, 07:47 PM
Dave03S's Avatar
As above until you need it resealed. Not sure but I assume by prior experience for that to be about the third 60k fluid service interval..
Old 03-24-2020, 09:04 PM
mollusc's Avatar
I don't recall any difference between my '99 and my '03 when servicing the transfer case.
But back to the OP, it certainly sounds like the t-case is the problem.
Old 03-24-2020, 10:53 PM
Jwehking's Avatar
Step back a minute. Are you sure it’s either in high or low range and fully engaged? A simple check, can you feel the shifter actually engaging between high-neutral-low or look underneath to make sure the linkage is connected and moving.
Quick Reply: 2004 neither shaft spinning
