265/60/18 BFGoodrich Long Trail tires?
Are these good tires? I have an 'opportunity' that I really can't pass up unless someone has good advice against them. I have the 18" 'Hurricane' rims, but these tires sound good.
What are you planning on using the tires for, will you be doing much wheeling? For the most part, they don't hold up or compare to the quality of the AT's and MT's.
You may have better options.
A general all around tire. My Disco II is my daily driver, but I want it to be able to go wheeling from time to time without hassle. I've heard good things about the General Grabber A/T, and I like the look of the Nitto Terra Grappler... Basically I have no idea about anything. I just know that the current tires are A.) Street Tires and B.)Need to be replaced within the next 10k miles more than likely.
These are a bit on the larger side of things so a lift would be recommended:
http://www.treadepot.com/tire/01401.html
There is an interesting article on the cooper website about these tires and land rovers
DV57
Oct 8, 2008 02:45 PM
raid13
Mar 17, 2008 08:52 PM
