265/75/16 on stock suspension
Old 08-25-2014, 09:27 PM
jrod770's Avatar
Default 265/75/16 on stock suspension
I have searched for quite awhile and could not find a definite yes/no answer. It's time for new tires. I want to put new 265/75/16 BF Mud Terrains on now and upgrade to an OME lift later, as money allows. I am reading mixed reports of bumper rubbing or no rubbing at all. Has anyone personally tried this and does it work? Thanks
Old 08-25-2014, 10:44 PM
abran's Avatar
Default Yes
I have a truck with those exact tires, but with an ARB front bumper.
No rubbing even when cranking the wheel hard for a u turn. The stock bumper might cause rubbing in the front.
Link with photos:
http://m.ebay.com/itm/261573556904?nav=SEARCH
Old 08-25-2014, 11:31 PM
abran's Avatar
Link didn't work...
Old 08-25-2014, 11:48 PM
Colorado David's Avatar
I had my tires on before I installed my OME lift. I didn't have any rubbing.
abran, where did you run your wiring for your work light?
Old 08-26-2014, 12:18 AM
abran's Avatar
Up under A pillar trim, then along the rack to the back.
Old 08-26-2014, 07:47 PM
jrod770's Avatar
Great, thanks. I was planning on doing shocks, springs, and tires all at once, however, I think I'm going to need the new tires before I get enough saved for the OME lift. Thanks for your input, and yes, pics always help.
Old 08-28-2014, 08:06 PM
evansjoem's Avatar
Originally Posted by abran
Link didn't work...
do u rub on the radius arms
Old 08-28-2014, 08:13 PM
abran's Avatar
No rubbing at all.
Old 08-28-2014, 08:36 PM
evansjoem's Avatar
Here is mine with the same size tires but with the lift.
Attached Thumbnails 265/75/16 on stock suspension-image.jpg
Old 08-29-2014, 11:28 AM
abran's Avatar
Update- Now that I am acutely aware of steering stops, I looked under the car and it seems to have the longer steering stops on it. Thats just a visual without measuring. I'll confirm later.
Quick Reply: 265/75/16 on stock suspension
