2x4 method for removing crankshaft bolt - we sure this won't break the engine casing?
Old Jul 2, 2021 | 12:19 PM
Brandon318's Avatar
Default 2x4 method for removing crankshaft bolt - we sure this won't break the engine casing?
I'm about to remove the crankshaft bolt as part of the front cover gasket replacement and it seems like the prescribed method of removing the bolt is to wedge a 2x4 between the block casing and a crankshaft balancing lobe. Are we certain that this method doesn't deform or risk breaking the actual block casting? Seems like an acute stress being applied in a direction it wasn't meant to support? Not an engineer. Just a smooth-brained ape.
Old Jul 2, 2021 | 03:00 PM
miron's Avatar
I did the "rope-in-the-cylinder" many times - works great.
Old Jul 2, 2021 | 05:12 PM
Brandon318's Avatar
lol, what?
Old Jul 2, 2021 | 05:31 PM
I assume he is referring to this
Old Jul 2, 2021 | 07:25 PM
miron's Avatar
https://www.youtube.com/watch?v=916MesBuShI
Yes exactly this. I'd only use the 2x4 if you want to bend your crank.
Old Jul 2, 2021 | 07:32 PM
Brandon318's Avatar
Oh! This is so much better. I'll do this instead. haha. Thanks!
Old Jul 3, 2021 | 01:47 PM
XRAD's Avatar
I have used a wedge between block and crank lobe, worked fine. The rope trick is nice, but no oil between connecting rod pin or piston pin...hmmmmmm..those are smaller bearings than using the crank bearings alone with crank wedge...
Also, a high powered impact gun can knock it right off without and wedges....
Is block in truck? can you lock the ring gear..i think there is an LR tool for this....
Old Jul 3, 2021 | 07:37 PM
The Deputy's Avatar
Future reference...
Take harmonic balance bolt out...before...you remove oil pan.
Remove rubber plug that covers trans flexplate bolts to flywheel, turn flywheel until you can see an opening in flywheel, slip a 19mm deep well socket/with extension through hole and into opening in flywheel, turn crank until deep well socket stops rotation, use breaker bar to remove bolt.
Old Jul 3, 2021 | 07:53 PM
Brandon318's Avatar
Future reference...
oh awesome!! I actually haven’t taken the pan off yet so I’ll try this.
cvhyatt
May 15, 2019 08:07 PM
jamestfl
Feb 10, 2017 09:47 AM
EVN137
Mar 4, 2012 08:21 PM
jcrenfrow
Jan 9, 2012 07:42 AM
twaszak
Nov 26, 2010 01:41 PM
