3 amigo code test cost
So my amigos have been going on and off intermittently since I've owned it. When they are off everything works (ABS, TC, HDC). When they are on nothing works. This leads me to believe it is a shuttle valve problem which could be fixed by option B on the abs repair. Am I wrong here? Could one bad sensor also have the same symptoms? I called the local indy shop and they said they would read it for $45. Should I get the read or go about option B? Thanks.
I would get the codes read. Probably will require the Option B shuttle valve fix, but if it is a speed sensor problem as well, you don't want to do the shuttle valve just to find out that it didn't fix it completely. I have also seen others on here rent our their ABS amigo scanners for $20 for a week...
DiscoBenjamin
10-14-2011 05:53 PM
