3 amigo code test cost
Old Jan 25, 2013 | 02:43 PM
MC04DII's Avatar
Default 3 amigo code test cost
So my amigos have been going on and off intermittently since I've owned it. When they are off everything works (ABS, TC, HDC). When they are on nothing works. This leads me to believe it is a shuttle valve problem which could be fixed by option B on the abs repair. Am I wrong here? Could one bad sensor also have the same symptoms? I called the local indy shop and they said they would read it for $45. Should I get the read or go about option B? Thanks.
Old Jan 25, 2013 | 03:42 PM
bballjames's Avatar
I would get the codes read. Probably will require the Option B shuttle valve fix, but if it is a speed sensor problem as well, you don't want to do the shuttle valve just to find out that it didn't fix it completely. I have also seen others on here rent our their ABS amigo scanners for $20 for a week...
Old Jan 25, 2013 | 05:25 PM
MC04DII's Avatar
I'm cheap ha. I just got the $3 trailer wire, and will do this tmrw morning. Seems easy enough. If it fixes it, great. If not, I will get the codes read and this will just be preventative. Thanks
Old Jan 25, 2013 | 08:46 PM
bosshogt's Avatar
I have the ABS Amigo to rent. I have rented it many times to forum members. That way you can tell what is really going on. Hit me up on a PM if you want.
Robover01
Nov 27, 2009 11:30 PM
Princess
Jul 4, 2009 12:24 PM
