3 amigos
3 amigos
I have an 2001 Discovery with 88000 miles on it. The three amigos recently showed up. Mike, you have asked in previous threads about squealing brakes. Well, mine were squealing before the lights came on and I do not have and vibration in the front end. I have also taken it to a brake place and other than the rear rotors being slightly out of spec (too thin), the brakes are in great shape. I also took it to Autozone to see if they could read the codes. No codes available (can only read code if it is a check engine light). Does anyone have any insight to this problem and what I should do to correct the dreaded three?
Thanks,
Thanks,
cammyr01
01-05-2015 03:42 AM
