3 amigos
Old Jul 10, 2008 | 03:32 PM
georget's Avatar
Default 3 amigos
I have an 2001 Discovery with 88000 miles on it. The three amigos recently showed up. Mike, you have asked in previous threads about squealing brakes. Well, mine were squealing before the lights came on and I do not have and vibration in the front end. I have also taken it to a brake place and other than the rear rotors being slightly out of spec (too thin), the brakes are in great shape. I also took it to Autozone to see if they could read the codes. No codes available (can only read code if it is a check engine light). Does anyone have any insight to this problem and what I should do to correct the dreaded three?
Thanks,
Old Jul 10, 2008 | 05:06 PM
Default RE: 3 amigos
Fix the brake squeak, new pads or sound deadening material then go find a shop that can check and clear the codes. It will cost you $100 plus to have them read.
majrmike
Jun 6, 2016 03:05 PM
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
offroader
Jun 16, 2007 12:31 AM
skrams
Feb 7, 2007 11:50 PM
