3 Amigos coming on sporadically
Old Feb 11, 2016 | 08:39 AM
slink182's Avatar
Default 3 Amigos coming on sporadically
Hi. I've got an '01 DII that just had the rear calipers, pads and rotors replaced. I would typically do this myself but schedule didn't allow so I took it to my local (non-Land Rover certified) mechanic. Seems like a pretty straightforward job.
However, since I've gotten it back, the 3 amigos come on intermittently when driving. If I stop and turn the truck off, the don't always come back on. I drive about 12 highway miles to work each day and on some trips they never come one but other times they do after a couple of miles. They have also come one just running around town.
I've taken a quick look at the shuttle valves on the ABS modulator, but didn't see any leaks. I'm wondering if this could just be a loose speed sensor when they replaced the calipers and brakes? I have the Rave so I will look up the rear speed sensor location at lunch, but thought I would post here to see if anyone had any other suggestions on things to check.
Also, I am planning a trip up to the mountains this weekend. Is there any danger in driving 2+hours (each way) with the lights on? I will have wife and kid with me.
Finally, is there anyone around Charlotte, NC that has a code reader that can read the ABS system?
Thanks for the feedback.
Old Feb 11, 2016 | 09:35 AM
drowssap's Avatar
without codes ? could be anything from a seed sensor to a hub falling apart.
if the light hasnt locked in, it maybe something small.
with the amigo's ON, not only with the abs not work, but i believe the traction control nor the hill decent will work either.
Old Feb 11, 2016 | 10:09 AM
Alex_M's Avatar
That's correct, none of the three (ABS, TC, HDC) will work at all with the amigos illuminated.
If it wasn't leaking, then you can always do the option B bypass and clean the wheel speed sensors to see of that fixes anything real quickly and cheap. Best bet, like you said, is finding someone with a scanner or buying a scanner for yourself. I actually believe there's an iCarSoft scanner for sale in the classifieds section of the forum right now. I believe those do ABS codes.
Old Feb 11, 2016 | 10:26 AM
drowssap's Avatar
icarsoft i930 will read and clear abs codes
Old Feb 11, 2016 | 10:34 AM
jamieb's Avatar
If it's just only come on, I would start with the wheels first. After that, it's not really a bad job doing Option B with the right tools (the allen wrench socket/ratchet).
I saw people order the wire harness online and wait, O'Reilly carries these every day.
Hopkins Manufacturing 47965 - Trailer Wire Connector | O'Reilly Auto Parts
These are a little harder to find if you decide to not cut and splice but just tap into a ground wire and the green/yellow wire
Amazon.com: Posi-tap Connector, 20-22 Gauge Wire, Pack of 5: Automotive Amazon.com: Posi-tap Connector, 20-22 Gauge Wire, Pack of 5: Automotive
Old Feb 11, 2016 | 12:28 PM
slink182's Avatar
Thanks guys for the info & links. I'm replacing the right front window motor tonight so I'll take a look at the wheel speed sensor while I'm at it. Stay tuned.
Old Mar 21, 2016 | 08:52 AM
Hhollar1's Avatar
02 DII (my first LR)
I'm having similar problem.when I hit brakes to hard. Sometimes will reset on restart.
No codes on obdII. Suggestions?
Old Mar 21, 2016 | 09:07 AM
Alex_M's Avatar
Did you try the suggestions already posted above? If not, use the information already at your disposal and start there.
Old Mar 21, 2016 | 09:10 AM
Hhollar1's Avatar
Will check those after work today. Thanks for the quick response and this is very helpful!
Old Mar 21, 2016 | 09:03 PM
Extinct's Avatar
I have a scanner and a located in Greenville SC, may be coming to Charlotte tomorrow or Wednesday. My 99 is doing the same thing, scanner says it is an inlet valve. No leaks on mine either.
