3 amigos questions
Old Apr 6, 2008 | 01:56 AM
Disco2Guy's Avatar
Default 3 amigos questions
Well it had to happen sooner or later I guess. At the end of the day I made two quick runs through the mud pit and two runs through the water pit. Just as I was leaving Hollister, the 3 amigos turned on and won't turn off after re-starting the engine. The couple times they have come on in the past they would go away with a re-start.
The brakes are also squealing like mad around 5-10 mph when stopping. The pads were sprayed with brake cleaner last month when the lift went in and the sound deadening goop was applied too. I need a road (gravel?) to test the ABS and feel for the pulsing sensation in the pedal, but how fast should I be going when I hit the brakes? I'm debating on going to an indy repair shop here in the city to get the codes read or just taking it down to Cerrone's (about 30 miles away) and have them take care of it.
Is it worth taking the tires off and looking for any mud I may have missed around the wheels/brakes? I was going to use a power washer (used garden hose instead) but in California you can't use them for the engine compartment or under carriage according to the stalls I stopped at on the way home.
Thanks
Old Apr 6, 2008 | 07:55 AM
Default RE: 3 amigos questions
Before you see Frank or another shop, you have to power scrub the brakes, getting rid of all of the mud cause it will just continue to make noise and keep the trio on.
Most likely after cleaning everything up, you can clear the codes and they won't come back on.
Old Apr 6, 2008 | 12:36 PM
Disco2Guy's Avatar
Thanks Mike, will keep you posted.
Old Apr 14, 2008 | 01:25 PM
Disco2Guy's Avatar
Last weekend, after using the garden hose to wash the mud off, I used a power washer on the wheels too. This morning I took it down to Cerrone's and had the codes read and cleared. There was an intermitent sensor fault and one for the shuttle valve, as far as the 3 amigos are concerned. The 3 amigos stayed off on the way home ~40 miles. Here's hoping that they stay off for a good long while. If it is the shuttle valve, Tony mentioned a kit that might be able to fix this, it sounds hit and miss at best for a repair. Has Wabco made a newer version of the modulator so I won't be in the same boat if it gets replaced?
Edit: I also just found this too.
Thanks
cammyr01
Jan 5, 2015 02:42 AM
Spencerfitch
Jul 24, 2011 01:28 AM
jarrcr
Sep 27, 2010 09:31 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
joelgriffiths
Aug 30, 2008 01:34 AM
