3 Amigos Repair -- Lessons Learned
Old Jul 13, 2013 | 07:30 PM
ukwildcats's Avatar
Default 3 Amigos Repair -- Lessons Learned
Last weekend I replaced my front left hub -- it wast toast, grinding like metal on metal. It had been acting up for a few weeks and right after/before it started making noise the 3 Amigos Showed Up.
I purchased a used hub from Paul Grant which was cheap and delivered quickly. I installed last weekend hoping the 3 Amigos would go away -- They did not.
Lesson Learned -- check the Hub Puller from the Loan-a-Tool at the Auto Parts Store (in my case Advance) -- the treads were stripped and I spent way to much time thinking I had a stuck hub when in fact I had a bad tool.
My Amigo Code reader has consistently showed a "Left Front ABS Sensor Low Voltage" which I was hoping that was caused by the bad hub -- But I was wrong.
Replaced the ABS Sensor on the front left with a replacement purchased off of EBay -- original configuration with connector in the engine bay on the fender.
Amigos are currently gone -- will advise if that changes.
Lessons Learned
-- When I replace the hub again I will assume the ABS Sensor was damaged by the hub. There was was minor damage on the head of the sensor that I was hoping was not a problem and I was wrong.
-- Just because a sensor passes the multi-meter test does not mean it is good. I tested from the connector in the engine bay and at the ECU Slabs with the multi-meter and both times it seems correct.
-- I installed by compressing the connector a little (flattenely) and passing through wheel hub opening and slowly passing the wire through this opening until I could install the ABS Sensor. While tight it was doable, I used a flat blade screwdriver and hammer to help.
-- I did have to remove one (1) of the hub bolts (nearest the driver) to gain a little extra room and release ABS Sensor bracket but that way it. Thanks goodness the Rover Serice Manual was incorrect.
-- I did put a dab of grease on the tip of the ABS Sensor before installing (another forum member's "Lesson Learned")
UK
EricTyrrell
Feb 12, 2012 10:12 AM
KyShark
Dec 17, 2010 01:21 PM
Frank4
Feb 6, 2010 09:44 PM
humroot
Jan 3, 2010 01:41 PM
humroot
Dec 2, 2008 06:57 PM
