3 Amigos still there after repair?
Old Aug 8, 2013 | 10:23 AM
captain203's Avatar
Default 3 Amigos still there after repair?
well I have been visited by the 3 little friends. I did the wiring bypass method using the two wire connecter. following the step by instructions. Well I still have them .
any ideas? anyone in the Toronto area with an abs scanner?
Old Aug 8, 2013 | 10:25 AM
Sure, that doesn't fix anything but the grounding issues, there are a total of 16 reasons for the lights to come on, you need to use a 3 amigo scanner and get the fault codes, then fix and clear your problem
Old Aug 8, 2013 | 10:28 AM
captain203's Avatar
that's what I figured.........guess I need to find a scanner
Old Aug 8, 2013 | 10:46 AM
sharpshooterjohn's Avatar
8th Gear
I had the 3 amigos and purchased an Autel 619 scanner for around $160. After updating it was able to read the abs codes and clear them.
Old Aug 8, 2013 | 11:02 AM
caymandrew's Avatar
I rented one here and was very happy to say goodbye to my little friends!
ABS Amigo V1 USB - Discovery II - RENTAL - Rentals - Tools
Old Aug 8, 2013 | 11:24 AM
NickAdams's Avatar
Does anyone know if the Harbor Freight Cen Tech 60794 is a "re-badged" Autel 619? Or has anyone tried the HF ABS scan tool on their 'Rover?
Old Aug 8, 2013 | 12:07 PM
8th Gear
The harbor freight 60794 is a rebadged Autel MS609 which may be able to read the ABS codes depending on the updates. However, it may not be available. I ordered one online a couple weeks ago and the order is still processing. I finally gave up and bought the AL619, since I knew it would work.
Old Aug 8, 2013 | 01:26 PM
NickAdams's Avatar
Thanks for the speedy reply. Did you cancel the HF order?
glassman66
Apr 19, 2012 10:17 AM
StormTroopa
Nov 28, 2009 06:45 AM
redhawk
Sep 20, 2008 02:53 PM
NJDisco
Feb 29, 2008 10:37 AM
