3 Amigos and their angry RED friend
My Red BRAKE light is on along with the Three Amigos. I checked the brake fluid and its fine.
I tried cycling the key three times and now after the car starts, the red BRAKE light and the ABS light stay illuminated and then the TC and HD light come on after about 3 seconds. This is without the car moving.
Also, it finally snowed so I was able to verify that I do NOT have ABS.
I had the codes scanned with a generic reader and the only code that came up was P0455.
There's no brake dust and my brake pads look brand new.
Thanks,
John
'02 Discovery 113k miles
Thanks,
John
You need to have it scanned by a Land rover Dealer or a small independent Land Rover shop. The cheaper code scanners will not pull the codes for the ABS. It has to be a Land Rover specific scanner. As for the P0455 this is what I found. It could just be a loose gas cap. Turn the cap untill you hear 3 clicks.
P0455
Generic
Evaporative Emission System Leak Detected (gross leak/no flow)
Willie
P0455
Generic
Willie
marsyas
02-25-2021 08:11 AM
strictlyb
01-28-2010 11:10 PM
