3 Amigos & Transfer Case Problems
Old Mar 25, 2013 | 10:34 PM
Dirty Dora's Avatar
Default 3 Amigos & Transfer Case Problems
Hi there,
I currently have the 3 amigos lit up, the nearest dealership with a diagnostic tool that can read my 2000 Disco 2 TD5 is over 2000km away. I have tried a G-scanner that I have borrowed from work, but it doesn't seem to be able to read the disco. I have heard that you can buy a cheap tool off the internet that can read the disco codes, anyone know about or used this?? In the meantime I am going to clean all of the ABS sensors to see if this will help.
The next issue is that with the engine idling while I was outside the car I could hear a rattle noise, upon inspection I found the culprit to be on the rear of the transfer case as highlighted with the screwdriver in the pic attached, seems to be about 10mm play up and down with this part and there is quite a bit of oil leaking around this area. I don't know what the part is that I am pointing too any ideas as to what is the problem would be a great help.
Cheers
Tommy
File Type: pdf
Old Mar 25, 2013 | 10:58 PM
caymandrew's Avatar
Rent the reader from these guys:
ABS Amigo V1 USB - Discovery II - RENTAL - Rentals - Tools
Old Mar 25, 2013 | 11:06 PM
Dirty Dora's Avatar
i'm not sure if they will rent to Australia!
Old Mar 26, 2013 | 03:11 AM
jafir's Avatar
Go to Australian Land Rover Owners
They have a sticky thread on that forum of people that have tools like nanocom that will help you read your codes, usually for free.
Old Mar 26, 2013 | 03:14 AM
jafir's Avatar
Members with diagnostic equipment - Australian Land Rover Owners
Old Mar 26, 2013 | 05:08 PM
Dirty Dora's Avatar
Cheers Jafir, I've located a diagnostic tool in town!
Old Mar 27, 2013 | 03:39 AM
Dirty Dora's Avatar
Turned out to be SHUTTLE VALVE ELECTRICAL FAILURE i hope following the steps on this link will solve my problem ABS Mod - LAND ROVER CLUB V.I.
Old Mar 27, 2013 | 03:49 AM
Solutions12's Avatar
Hope you manage to get the issue resolved as soon as possible!
Old Mar 27, 2013 | 12:30 PM
drowssap's Avatar
code 4114
shawnjkelley
Feb 1, 2012 10:24 AM
blondebunny
Jan 28, 2011 03:58 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
gsxrgessler
Apr 18, 2010 09:58 PM
