3 Amigos won't go away
ABS Amigo - Cheapest way I've found to do the ABS codes reliably. Requires a windows pc to pull the codes, but very user friendly.
Discovery II - ABS Amgio V1 USB
Ultragauge - Can't beat the price, I've been meaning to put one in every car I own. Real time temp is worth that price alone in the Rover.
UltraGauge OBDII Scan tool & Information Center
Dave
Dave
To disable the system to make it drivable pull the ABS relay in the engine bay (not sure which relay, toward the back next to the SLS relay i believe) THIS WILL DISABLE YOUR ABS! USE CAUTION! My truck was doing the same thing, TC would engage any speed over 10mph, turned out to be a sensor that wasnt seated all the way down.
Look in the parts section, ABS Amigo might be for sale or look for someone that will rent you one.
Someone that had one for rent (just a quick google search)
abs amigo rental - Land Rover Forums : Land Rover and Range Rover Forum
Where did you get those codes you posted? is it a LR shop? Those aren't ABS amigo codes so i cant look them up on here:
http://www.rswsolutions.com/index.ph...d=38&Itemid=65
you have to get your hands on an Amigo to really troubleshoot this, you cant be running back to the shop evertime you try something different.
I got some help from Storey (forget his last name, really helpful guy) who developed the ABS amigo, he said the most common error is sensor installation.
How did this all start? Out of the blue or were you messing with something?
Out of the clear blue one day. Turned the key on and they never went off.
The $400 was labor included.
The shop that did the work printed those codes out. I guess I won't be going back there.
I usually do any of the work myself, unless I get lazy. I'm ready to ROCK now!
ABS Amigo is the best thing to buy. Even if you go somewhere, get something fixed and your warning lights go away…they'll be back some day. The Amigo is excellent. I did a 4x4 trip last weekend and my 3-amigos popped up on three separate occasions. I just plugged my ABS Amigo in and the lights went out.
In my case there isn't any problems aside from my sqeeky brakes keep setting them off.
Good luck with it all. FYI I bought my Amigo used for $125 online. There are often people selling them through Rover sites etc.
I would take a look at the Autel 619. It scans and clears engine codes, as well as ABS and SRS codes. It also does live data, though not as extensive as what I was used to, but you"ll get coolant temp, O2 voltage and a few other useful parameters. I've got one and it worked as advertised, just needs a software update initially.
Dave
Dave
r.serio,
When your finished with your 3 Amigos, let me know if youd like to rent me your scanner
My Amigos are driving me nuts too.
Dave
Dave
