3" vs 2" OME ---> Help!
Old Feb 13, 2011 | 07:43 AM
  #31
humroot's Avatar
Originally Posted by Urban Panzer
I dont know if it has been mentioned yet at all, but incase it has not then you will need to change / use Disco 1 spring seats if you use D1 springs as they are different to the D2.
Really? I have been running these springs for years and did not change the spring seats. I have had no issues at all.
Old Feb 13, 2011 | 07:57 AM
  #32
humroot's Avatar
Originally Posted by yloDiscoII
I would appreciate it. Ordered by steering stabilizer but haven't gone for the lift yet. Thanks! What size tires you running?
Here is a pic of my DiscoII. OME 751's in the front and SLS Spacers in the rear. I'm running General Grabbers in 255/70/16...I had them before the lift. If I had to do it again, I would get the DuraTrac's in 265 or 285 to fill in the wheel wells.
Old Feb 13, 2011 | 06:36 PM
  #33
Urban Panzer's Avatar
Disco 1 springs are ground flat both top and bottom, hence the spring seat is flat, disco 2 front springs are not flat on the bottom end, the last bit of the coil hangs in a key way in the spring seat.
Old Feb 14, 2011 | 10:05 AM
  #34
dcarr1971's Avatar
They are about 14mm thick, seems to be enough on mine and a friends, but different cars "may" be slightly different.
Perfect. Thanks for the info. I installed the TF 3" lift Friday night. It looks and handles great, but I had to remove the cross-member. It will go right back in as soon as I have a chance to cut some scrap steel into a set of spacers.
Old Feb 14, 2011 | 06:22 PM
  #35
yloDiscoII's Avatar
Just ordered the 2" OME kit from Lucky8!
Old Feb 18, 2011 | 09:48 PM
  #36
yloDiscoII's Avatar
LIFT ARRIVED TODAY! 2" medium duty springs with the sport shocks....It's like friggin' Christmas I am lucky that ARB is literally less than 15 minutes from my house....It'll be a couple weeks before I get tires, so the llift will be collecting dust for a little while but I'll be sure to post pics when it's all said and done. Thanks everyone for the input
jycsalas
May 23, 2019 03:02 PM
oysterhead
Jun 10, 2010 02:27 PM
Spencerfitch
Apr 27, 2010 06:03 PM
Disco Mike
Nov 1, 2009 11:25 AM
caustin
Feb 15, 2009 04:14 PM
